flote21
Advanced Member level 1
- Joined
- Jan 22, 2014
- Messages
- 411
- Helped
- 1
- Reputation
- 2
- Reaction score
- 3
- Trophy points
- 1,298
- Activity points
- 5,595
the input voltage is negative and the power supply is between 0 and a positive voltage
In real life will happen more or less what you see in the simulation. I do not understand your question... why are you surprised?
No, a simulator is not easily fooled by such a setup. The simulator is showing a correct response.You're saying the op amp is powered by a single-ended positive supply. It cannot handle a negative voltage. (A simulator is easily fooled by such a setup.)
Operating guidelines state you should only apply a voltage to the input which is within the supply rails.
The voltage is interest is not the resistor input voltage but the voltage at the op amp (-) input. As long as that doesn't go significantly below the negative supply (for a rail-rail op amp) you are okay.
You are correct for those circumstances. Furthermore LTSpice is more likely to act correctly than the simulator I use (Falstad's). I have seen Falstad's op amp model act simplistically, too simplistically.
So it means that the LT6015 should work on real life when input voltage is -2 and is supplied between gnd and +5V?? with Gain=-1 of course!
Thanks
The LT6015 does not work with input voltages of -2V.
But the shown LT6015_circuit does work with input voltages of -2V at the resistor.
Start your simulation again and measure the true OPAMP input voltages at IN- and IN+ and see that both are close to 0V.
(Not -2V)
Klaus
Yes, I was referring to Spice derived simulators which use the manufacturer's particular device Spice model for simulation.You are correct for those circumstances. Furthermore LTSpice is more likely to act correctly than the simulator I use (Falstad's). I have seen Falstad's op amp model act simplistically, too simplistically.
Yes, look at the Vcm "Input Voltage Range" in the LT1881 data sheet.Not surprising at all. Problem is not reading the datasheets thoroughly. LT1881 is specified as "rail-to-rail output" device, datasheet never claims R2R input operation.
I'm confused.Ahhh ok I get it why the LT1881 is not working....but then why the simulator is hanged with the LT6015?? It will work on real life?? Or there is an issue in the simulation model??
I'm confused.
In your first post you stated "According to the simulation is working" but now you say it won't simulate. :-?
What's the difference between the two simulations?
