LT317 voltage ref problem
orienteraren
Junior Member level 1
Hi! I just got my LT317 voltage regulators. I do need a very precise output on 1.25V so I did the design found in the datasheet ( http://www1.elfa.se/data1/wwwroot/assets/datasheets/07331713.pdf ) under typical applications 1.2-25 v adjustable regulator. I connected everything and feed it eith a +12V source. On the output I get 11.52V no matter what I do. I tried to feed it with a 5V supply but the problem is tha same, the output is just a fraction of the input no matter what I do on the trim potentiometer (I´ve tried 0-5kohms with no change in output).
What am I missing? I suppose I´m misusing the componen but how?
Regards
Fredrik
Whats exactly your circuit pls?
You will never have an output of 1.25V with these IC_remember pls; Uout=Urefx(1+R2/R1)! :-(
It will for you deliver Uref (1.25V) + some(depending of relation R2/R1) to the output.
K.
If you connect the ADJ pin to 0V then the V[out]-pin will produce 1.25V ..
Make sure you have the pin configuration right ..
IanP
Did you measure the voltage between Vout and ADJ? It should be 1.25V. The voltage ADJ to GND should be near 0V.
What is your resistor value for R1? R2/R1 needs to be near 0 to get 1.25V output, so you should set R1 >> R2 (or ground ADJ directly).
I guess there's no problem with the resistors though, do you have an oscilloscope to check if the regulator is oscillating? Try adding a smaller value one (some nF) to the input and output (additional to the 1uF one).
Attached is a circuit based on the LM317 that allows for small output voltage adjustment and in the same time provides a lightweight "dummy" load ..
IanP
:D
