[SOLVED] LT1513 SLA Battery Charger Simulation with LTSpice
Dr Phibes
Newbie level 3
Newbie level 3
Help Needed - LT1513 SLA Battery Charger Simulation with LTSpice
This is probably a basic question, but I'm struggling to understand why (in LTSpice at least) a resistor appears to be needed upstream of the battery's positive terminal in a LT1513 circuit.
None is shown in the LT1513 datasheet, but it is included in the LT1513 test fixture, and this circuit (which is may attempt at a DC UPS with a SLA battery) appears to need it.
Image:
Any ideas? Feel free to comment on the rest of the circuit - surprisingly few references to doing this with these chips on the web.
Thanks in advance,
Lee
If you mean 'why is the resistor needed to make the simulation work?' it is most likely to prevent a theoretical infinite current on power up due to a capacitor across a voltage source. That is a common cause of simulation failure when using ideal components.
Keith
Keith
Ah, that makes sense. Thanks very much.
Lee
You can use a resistor value which doesn't affect the operation while avoiding the infinite current such as 0.001 ohms.
Are you a Vincent Price fan?
Keith
