iceblu3710
Member level 3
I find it quite off but Mouser does not carry any products from Linear Technologies. I was looking for a LT1037 when I realized it.
So I need help trying to find a suitable replacement that I can get from Mouser. Here is the proposed project:
A Wien-Bridge Oscillator that has a THD = <0.05 with a noise floor of -100dB. I have sourced all the tight tolerance capacitors and the multi position rotary switch but without a very high quality op-amp the project is pretty useless. I am planning on putting two of these oscillators in a case with several additional stages. One would provide the sine wave output with amplitude and offset control. The Wien-Bridge would feed another two stages as well, one being a square wave with adjustable duty cycle and the other a sawtooth generator. Each can be generated from the previous however as each stage introduces noise the Wien-Bridge require a very clean and noise free output.
So anybody know a suitable op-amp?
