desgin
Full Member level 1
Hello Experts,
I am facing Ethernet port issue with the NXP board LS1043A-RDB
Setup:
Requirement:
Thanks in advance!
Regards
Linux Developer
Setup:
- All 7 ethernet ports of NXP boards are connected with 7 different Linux system ethernet port through LAN cable
- Only 1 ethernet port of NXP board is connected to Linux system 1 but still able to ping other 6 ethernet ports of NXP device through static IPs
Requirement:
- Need to connect all 7 ports independently to work with independent system.
- Able to ping only 1 ethernet port of NXP device from Linux system 1
- Speed should be at least 1 Gbps
- Image 1: Architecture of NXP board and Linux system 1
- Image 2: NXP device static IPs - through ifconfig
- Image 3: Static IP of Linux system 1
- Image 4: Ping 1st ethernet port - static Ips of NXP board from Linux system 1 - Expected response
- Image 5: Ping 2.. ..7 ethernet port - static Ips of NXP board from Linux system 1 - Unexpected response
Thanks in advance!
Regards
Linux Developer
