LPKF C100/HF prototyping equipment
fahsa
Member level 2
Member level 2
lpkf c100/hf
Has anyone worked with LPKF C100/HF prototyping equipment. I am having trouble connecting the compressor (Profimaster Plus 255-50W Silent) to C100/HF.
Also I want to know how the LPKF autoswitch will be connected between the C100/HF and vacuum filter
coul'd you explain better what kind of problems do U have connecting compressor?
I' have a LPKF C30 /pneumatic , The head work on a air pillow as for C100.
I've connected directly air compressed source to the LPKF using the "quick" disconnect air plug to the "Rielsen(R)" tube 6x1 mm.
Did U used 0.15mm RF milling tools? Have U experienced an extremally low life?
I have a off-line question. I am a radio amateur and would like to make some microwave PCB's I have rogers PCB but it would be best to use a LPKF device to make the PCB since other way's are not so good..
Who can help me out ??..
Paul.
