As the paper clearly explains, the LPDA is suitable for extremely wideband operation, and it was shown that its features can be used also with a parabolic dish. All features you listed are described extensively.
Horn primary radiator in a parabolic antenna is usually not so wideband; It usually ends a rectangular waveguide feed, so the antenna frequency response is determined by it.
There are also specially modified wideband horn antennas that can be used as a primary feed of the parabolic reflector.
With your 0.6 m parabolic reflector, your LPDAs covering 8-14 or 8-16 GHz would offer a higher gain; some matching problems should be expected due to dish reflection.
