raman00084
Full Member level 6
i am designing lpc1768 pcb, when looling at lpc1768 data sheet from nxp the uart are repeated uart1 is repeated two times, uart2 is repeated two times and finally uart3 is repeated 3 times
p0(0) - TXD3
p0(1) - RXD3
p0(25) - TXD3
p0(26) - RXD3
p4(28) - TXD3
p4(29) - RXD3
p0(10) - TXD2
p0(11) - RXD2
p2(8) - TXD2
p2(9) - RXD2
THE PWM IS ALSO REAPTED LIKE
P1(18)-PWM(1) CHANNEL1
P2(0)-PWM(1) CHANNEL1
KINDLY TEL WHICH I/O I MUST USE FOR THE FOLLOWING
UART1
UART2
UART3
PWM
THANK YOU
p0(15) - TXD1
p0(16) - RXD1
p2(0) - TXD1
p2(1) - RXD1
p0(0) - TXD3
p0(1) - RXD3
p0(25) - TXD3
p0(26) - RXD3
p4(28) - TXD3
p4(29) - RXD3
p0(10) - TXD2
p0(11) - RXD2
p2(8) - TXD2
p2(9) - RXD2
UART1
UART2
UART3
PWM
THANK YOU
p0(15) - TXD1
p0(16) - RXD1
p2(0) - TXD1
p2(1) - RXD1
