ngmedaboard
Member level 3
- Joined
- Feb 7, 2010
- Messages
- 60
- Helped
- 7
- Reputation
- 14
- Reaction score
- 4
- Trophy points
- 1,288
- Location
- United States
- Activity points
- 1,831
I have a low frequency boost converter (about 700Hz) that uses a 4.7uH inductor coil and generally has a very low duty cycle (I can't say exactly what the duty cycle is but the circuit is essentially designed to put out a pulse whenever the circuit is outputting below 68.5V).
With that said, I have found even with a decent sized output cap on there, this circuit is easily loaded down by a multimeter with a several hundred ohm divider and was wondering if anyone had any suggestions as to how I could reduce the impedance of this power supply by simply changing the inductor? Would a higher inductance help?
