Teszla
Member level 2
Oskar has purchased a station building to his model railroad. The lighting in the house consists of 10 light bulbs connected in series, marked 2.4V/0.1A. Unfortunately the lamps often brakes so Oskar decides to change to orange-colored LEDs.
Oskar buys 10 orange colored LEDs and 3 resistors, each with the resistance 100 Ω. The diodes must be connected in series with a current of 20 mA and voltage fall of 2.1 V over each diode, according to the manufacturer's recommendation in the included datasheet.
Help Oskar to design the circuit.
In the first case 10 lamps with 2.4V/0.1A gives 24 Ohm per lamp, hence are all lamps equivalent to a 240 Ohm resistor. With a current of 0.1 A this gives a voltage of 24 V.
In the second case there are 10 LEDs with 2.1V/20mA which gives 105 Ohm per lamp. This gives an equivalent resistance of 1050 Ohm. Using the same voltage as in the first case, the current through the lamps will be 24V/1050 Ohm = 0.023 A, which is a bit more than the required 0.02 A.
I understand the resistors must be put in the circuit to make the current go down to the required level, but how can we determine how the resistors should be connected? Is one supposed to just try and see if it works, or is there a more systematic method to find out?
