jonnybgood
Full Member level 4
I am designing a low res measurement circuit with these specs; 10mOhms(0.1V) to 100mOhms, <70mA supply current, +/-5V supply rails, and under 2% output error. Below is what I tried on Proteus;
Is this practical enough to build? I will add a reference 100milli Ohm 0.1% and switch to calibrate current source.
I tried to add an offset nulling pot but there was no effect on the simulation; probably it is not implemented in the spice model.
I also thought of introducing a reference voltage to calibrate the amplifier. What do you suggest?
thanks
thanks
