p72
Member level 3
Hi All,
I have attached circuit for Low Pass Filter at cut-off frequency 60Hz.
My input is 240VAC, 60Hz for this filter. My goal is to block all AC signal at the output of the filter (means I am looking for DC.).
Two questions: -
(1.) If I use attached circuit, can I get DC as an output of this filter?
(2.) What will happened to 240Vac voltage? Will voltage (240Vac) stay same after output of this filter? (If yes, how can make it to ground?)
Thank you,
p72
Two questions: -
Thank you,
p72
