"low output impedance" v.s. "rail-to-rail out
orap
Newbie level 1
Newbie level 1
hi there,
Is there any reference materials which addresses the problem between "low output impedance" and "rail-to-rail output range"???
I need to have a rail-to-rail output with low output impedance in a standard CMOS process. It just kills me.
Thanks.
Aaron
Re: "low output impedance" v.s. "rail-to-rail
It is just a thought, can we not buffer (unity gain configuration amp) at output of a class AB (rail-rail) stage.
what's the output impendence do you preferring? a R-R OPAMP plus push-pull MOSFET pair is an option.
mike
www.ezpcb.com
a 2 stage amp with push-pull output will do
what configuration r u using?
push-pull source follower will provide low output impedence as well as r-2-r signaling
This IEEE paper should help you.
regards,
srivats
  • cmos_op-amp_203.pdf
