Low noise Op Amp design
tia_design
Full Member level 1
Has any body designed low noise Operational Amplifier? In which way you minimized the noise? What i mean is mainly based on CMOS process.
Refer to "cmos analog circuit design"
allen
Chap 7
I think the noise is counter-proportional to the device size and you can increase the size to reduce the noise. And you can use large gate length to reduce short channel effect.
Yibin.
i remember one saying that PMOS is less noise than NMOS as electrons are moving faster than holes, hence create more noise.
SO for the input stage, PMOS pair is preferred.
