Hesambook
Full Member level 2
Features:
AC – DC Conversion
Double output voltages (Positive – Ground – Negative)
Adjustable positive and negative rails
Just a Single-Output AC transformer
Output noise (20MHz-BWL, no load): Around 1.12mVpp
Low noise and stable outputs (ideal to power Opamps)
Output Voltage: +/-1.25V to +/-25V
Maximum output current: 300mA to 500mA
Cheap and easy to solder (all component packages are DIP)
A double output low noise power supply is an essential tool for any electronics enthusiast. There are many circumstances that a double-output power supply is necessary such as designing pre-amplifiers and powering OPAMPs. In this article, we are going to build a linear power supply that a user can adjust its positive and negative rails independently. Moreover, just an ordinary single-output AC transformer is used at the input.
References
Source: https://bit.ly/2Qc9idO
[1] LM317 Datasheet: https://www.ti.com/lit/ds/slvs044x/slvs044x.pdf
[2] LM337 Datasheet: https://www.ti.com/lit/ds/symlink/lm137.pdf
[3]: Schematic Symbol and PCB Footprint for LM317: https://componentsearchengine.com/part.php?partID=248007
[4]: Schematic Symbol and PCB Footprint for LM337: https://componentsearchengine.com/part.php?partID=290650
[5]: Altium Plugin: https://www.samacsys.com/altium-designer-library-instructions
