walters
Advanced Member level 2
When i monitor a Low frequency oscillator or use a function generator that is set
from
1.) 0.05 Hz to 30 Hz
2.) 0.1 Hz to 25 Hz
3.) 0.2-12Hz
4.) 0.25-8Hz
A.) Why does a Analog oscilloscope use a Flashing strobing dot and not use a steady sinewaveform that you can visually or graphically see, so you can measure the period/time of the waveform?
B.) Why doesn't a Analog oscilloscope let low frequency be measure more clearly in real time?
C.) What would u have to modify in a Analog oscilloscope to make low frequencys at theses ranges more visual in real time?
D.) What kind of oscilloscope measure low frequencys better , that can do it in real time? (so its not flashing or strobing a dot)?
from
2.) 0.1 Hz to 25 Hz
3.) 0.2-12Hz
4.) 0.25-8Hz
