low frequency meter problem?
fireplus
Full Member level 3
hi,
may some body help me in how can i measure low frequency signal such as 50.73hz the most important is 0.73hz with small gate time like 0.2 sec
i made a frequency meter that can measure 500khz to 1 hz with a gate time 1 sec
but what about lower than 1hz frequency ?
Thanks for every body want to help
Fire in The Wire :idea:
Hi fireplus!
Use the low frquency signal as the gating pulse along with a clock to measure pulse width. Calibration of this result gives frequency.
Giri
hi,
but i still have to waite for more than one second for 0.3hz wave
is there any different alogrithm to do that with small gate time
Do a Google search for "frequency reciprocal counting" and I think you will find your answer.
For a graphical analysis of "zero crossing" versus "reciprocal counting" methods, by Michel Waleczek, you can look here:
https://www.m3electronix.com/recip.gif
    fireplus
I think using a triggered clock and a counter would do
the trick as Giri said. You need to trigger a clock when
the signal croos zero and count thepulses until the
next zero crossing . Ex., using half cycle of a 50 Hz
signal (20 MSec) to trigger a 10Mhz counting clock
will give you 100,000 counts, for a 50.3 Hz signal the
count would be 99,403.
