load is inductiveHi,
Input power factor? --> use a PFC stage
or output power factor? depends on load. What is your load?
Klaus
yes being load inductive ,we need PF near unity , how to attainWhat do you mean by "control powerfactor"? It's a property of the load, not the voltage source.
load is inductive
I suspect your assumption is incorrect for what appears to be 3kVA 3 ph source VFD and there is some type of inductive load where force or torque presents the real power but it is desired to get the near unity p.f. applied to the grid.on a purely inductive load you have 90° phase shift ... and it can not do something useful (since real power is zero)
Klaus
I read the question so that you are talking about a VFD. Power factor of 50 Hz AC input is not related to load power factor, in so far the question makes no sense.3phase 50hz power source is 5-140Amps ,8v-600v , frequency 0.01hz to 6hz
When you talk about torque ... then you probably talk about a motor. And for sure you are correct about a motor as load. Then the load is not PURELY inductive, but also contains an (non_induchtive) real part.I suspect your assumption is incorrect for what appears to be 3kVA 3 ph source VFD and there is some type of inductive load where force or torque presents the real power but it is desired to get the near unity p.f. applied to the grid.
Indeed I did not add anything. The given information is "inductive" and nothing else. I did not interprete the information. I treated it as given.Klaus: I believe you injected the word "purely" into your thought process and response.
load is inductive
