sarinsukumar said:I had posted a thread about "low cost pickit2 clone" making
after many reviews i have made it more simple. Like some thing u can make it with the controller (pic 18F2550) and some discrete components which are easily available.
No mosfets (difficult to find) not even bat 54 (schottky diode) . just few transistors and diodes.
which support programing and debugging + 5 and 3.3 V device support with protection circuitry.
You can find the full article here with schematics.
https://electronicsadvices.blogspot.com/2009/04/full-featured-pickit2-clone.html
Fragrance said:Hi
J have look the project and I like it,does work perfekt in programming?,and is there a pcb for unisocket for programing all chips,J mean like on the picture.
regards to all
macobt
sarinsukumar did good job but his mod has one disadvantage that it will required vcc from target shared design is much closer to orignal design and have debug fetaure for 3.3V and 5V device good thing is that single sided PCB design i also share orignal eagle design file hope friends like it.
also to Pranam77 i have uploaded all thing which required to make this nice mod
Regards
Fragrance
For the first time, you need to program the chip with another programmer. Once programmed, and inserted in the Board, the programmer is capable of self programming and upgrading the new versions of firmwares. Cheersmacobt said:Simple qwestion,The chip PIC18F2550 I must programm with other programmer or with this module of pickit clone???
