tylerjbrooks
Newbie level 3
I am designing a light dimmer for the US market that has power measurement capabilities. I am looking for a low cost solution. I want to be able to control/measure loads from 0W to 300W in 5W steps (or so) so accuracy is less important than cost.
My first thought was something like I have attached. I have built it on the bench with mixed result. The current sensor is 'touchy' as you might expect. I have also tried a couple traditional instrumentation amplifier configurations with a little better result. I find that in all configurations if I increase the AC voltage much past 120VAC, then the opamps become unstable and slam against the rails. I take this to mean that I am struggling with common mode voltage.
I guess I could use something like the INA148 but it is pretty expensive for our application (>$3 in Q1000). Is there a cheaper alternative? Maybe another approach? Maybe a better (and cheap) opamp that can take higher common mode voltage? Suggestions greatly appreciated.
