John_randio
Newbie level 2
In a typical feed-forward operational amplifier or for that matter any other negative feedback system, on countering a scenario where the loop gain of the system is greater than 0 dB and phase is -180 degree. One usually opts for Nyquist analysis to discern stability.
Even though this proves that the system is stable, is there an intuitive explanation as to why those frequency points where the gain is higher than 0 dB and phase -180 degree on a bode plot doesn't keep on adding to itself and lead to instability?
If the phase is truly 180 degree and negative feedback causes another 180, which causes a total of 360 degree around the loop, still the system is stable.
Any thoughts??
Any thoughts??
