Looking for VBS script that will eject a CD drive
warp
Newbie level 1
Newbie level 1
Does anyone know a vbs script, or a program that will let me eject a specific CD drive? Ive found one that will eject all the drives, but not one that will eject a specific one.
Re: cd eject script
Put this script in a blank text file and change extension to .vbs:
Set oWMP = CreateObject("WMPlayer.OCX.7" )
Set colCDROMs = oWMP.cdromCollection
colCDROMs.Item(0).Eject
Put the number of drive that you want to eject
(0 for D:\, 1 for E:\ and so on...) in colCDROMs.Item(n).Eject.
cd eject script
it havent worked
what is wrong
i copied the same in the notepad
and changed the (n) to 2 since my drive is F
but got a error.
line 3
char 1
error invalid procedure call or argument
code 800A0005
binu g
Re: cd eject script
Probably you need a newer version of Windows Media Player.
I have Windows Media Player 9 version with Windows Xp Sp2 and it works good.
cd eject script
ok
is there any way i can work it out in win2003
or any modified script can work?
binu g
Re: cd eject script
You should install windows media player, or try to find wmp.ocx
in your windows system directory and re-register it
with this command: "regsvr32 wmp.ocx"
It should work...
cd eject script
still i got the same error,
i re-register the wmp.ocx.
it got successfully registered.
regards
binu g
Re: cd eject script
Try re-register also wmp.dll
with "regsvr32 wmp.dll"
what version do you have of this file? Mine is 9.0.0.3250
Install the last version of windows script for windows 2003 here is the link
https://www.microsoft.com/downloads...82-e3f5-4289-a5e3-6cbb818623aa&displaylang=en
I have also found this script, but it doesn't work in my system :cry: :
Const CDROM = 4
For Each d in CreateObject("Scripting.FileSystemObject").Drives
If d.DriveType = CDROM Then
Eject d.DriveLetter & ":\"
End If
Next
Sub Eject(CDROM)
Dim ssfDrives
ssfDrives = 17
CreateObject("Shell.Application")_
.Namespace(ssfDrives).ParseName(CDROM).InvokeVerb("E&ject")
End Sub
cd eject script
i had it but it just ejects E: cd rom
Re: cd eject script
I made this little app, I hope that you find it useful. You need visual basic 6 runtime to run it, there is also the source code.
Regards
