Looking for unmanaged Ethernet switch with 6 ports
zape
Full Member level 2
Full Member level 2
Spain
broadcom5328
I need to implement an ethernet 10/100 switch on a backplane. One of my main constraints is the component height 3mm. I need at least an unmanaged switch (or one with RTBI or RGMII or SMII) with 6 ports. Does anyone knows some component fitting?
Re: Ethernet switch
Check out:
It's a managed 10/100 switch with 8 ports and some pretty impressive features.
On the next to the last page of the data sheet it lists the dimensions for the 208-pin LBGA as 17x17x1.4mm
Radix
Ethernet switch
MARVELL&BroadCom's Chip is better.
Ethernet switch
Some Taiwan's companys can provide cheaper solution, if you only need small port count.
Re: Ethernet switch
Broadcom 5328 and 5338 are rather popular and design easily. The two chips also integrate the PHY.
