Looking for this 8-pin connector
Build-A-Burger
Full Member level 1
Full Member level 1
Wyoming
Here's a connector for some seat motors under a seat I'm retrofitting into an older vehicle. I don't know what the seats came out of. Can anyone ID this for me so I can order another male connector? (sorry if this is the wrong section)
Here's a connector...
What you need is the manual to the particular vehicle and the connector. In vehicles those "connectors" are called harnesses and each car has unique types and amounts of them. The only way to get them is either order replacement or a junkyard scavenge. You may try to model and 3d print it too.
https://en.wikipedia.org/wiki/Cable_harness
Be warned there many harnesses in vehicle and some might be hard to find since they might look similar to others.
One of the most important parameter with connectors is the pitch.
Klaus
Connectors like that are common in vehicles but it's not likely you'll find an exact match. The variations are so numerous, as to spacing, diameter, plastic surrounds, interlocks, etc.
The quickest path is probably for you to buy a new pair (male & female). An auto parts store is a likely source.
Clip off the old connector. Solder on the wires. You would have to do some soldering in any case.
