Looking for RS485 circuit with only 2 wires
mtawab74
Member level 3
Member level 3
RS485 circuit
I need a circuit that uses rs485 driver where
there's only 2 wire between transimiter and receiver and those 2 wire carriers data between transimetter and receiver and also carry power from transimeter to receiver card
the receiver card operates at 8 volt and consumes 150 mA
thanks in advance
Re: RS485 circuit
Well, the problem you described may be a bit difficult to solve. There is no problem to transmit data only using just 2 wires as it is commonly used in various communication systems. Sending power supply of 150mA along with data (for long distances) using just 2 wires may introduce communication errors especially at high data rates and long distances. I recommend use of 4-wire cable where two additional wires are used only for power supply transfer. One must keep in mind not to transfer AC current as it will surely cause transmission to fail.
Re: RS485 circuit
You can try maybe with some small series transformer to modulate the powersupply with your data and extract it back on the other end with a transformer or capacitor...though you need to work in a frequency band high enough so it doesn´t get shunted by the power supply...
I would go with the hdcl capable controller from Zilog and operate with the similar protocol as Apple did once for localtalk...meaning runing at 230kbits/sec...
But maybe there´s a cheaper way?
Re: RS485 circuit
you can communicate data up to 160 kbps for 4000 meter with MT9172 from zarlink and send power and data on two wire (awg24 wire) and there is no problem ,I tested it and works nice.(only point to point)
you can also use MT8952 chip with it for data.
Re: RS485 circuit
Dear 7rots51
would you please post your schematics or send it to me by email
mtawab74@hotmail.com
Thanks for all replies
Re: RS485 circuit
REGARDING THE SOLUTION OF USING TRANSFORMER AND CAPACITOR I USED A CIRCUIT ATTACHED BUT IT GIVES BAD RESPONSE
AND DISTURT DIGITAL DATA PERIODES AND DELAYED IT
fo example while using 9600 bit/sec ( i used clock source 9600Hz 50% duty ) the high period was about 3 times the low period even the original
and some data sent are lost
Re: RS485 circuit
This is the information!
Re: RS485 circuit
Dear all finally i got a solution
the attached files contain 4 identical circuits that contains a darlington
those circuits simulat a coil which could be adjusted to any inductance value up to 10H
i used it and it performs very good
salam
RS485 circuit
have any one have idea for rs485 interface with opto isolation.
binu g
RS485 circuit
Dear 7rots51
bj_xxh@hotmail.com
thanks!!!
Re: RS485 circuit
use msan_124.pdf and MT9092 and MT9172 and MT8940 ,msas_42.pdf,...
in www.zarlink.com ,you can easy use the fig2 of msan_124 to generate stbus signals and use mt9092 to send data and voice over cable ,you can also mt8952 as data tx in hdlc format.
the sch of mt9172 is in its datasheet ,for trans buy you can get helps from zarlink support,they introduce you a hongkong company for it.
