Looking for program that can read IDF files
moses
Junior Member level 1
dos any body know a shareware or freeware peogram that can read Idf files?
idf file viewer
I have been looking and searching for a IDF file viewer myself never found anything.
So if anyone has something :?:
/P!SiX
idf files
you can read them as l2 files .emn and emp as libary and component with
your WordPad but YOY can bulid them in Mech with program Colled PCB23D
and you can find at Solidedge site !
idf viewer freeware
HI CADPCB
can you give me a link to the program as i could not find the PCB23D
program.
thnk in advance
moses
idf file reader
moses said:
HI CADPCB
program.
thnk in advance
moses
free idf viewer
hi,
Does anybody have any experiance with Expedition WG2000 IDF Export to PTC PRO/Engineer?
greetz, venz.
idf 4.0
we get PRO/Engineer idf files and inport to wg2000 no problem. did not try to export
idf file
circuitworks.
idf viewer free
Is there a plugin for Pads that will generate an IDF 4.0 file?
Eda
viewer idf
I am aware of V3 but not v4 IDf ??
how to read idf files
Apparently from the Circuitworks brochure there is an IDF 4.0 format. From what I am reading it can actually pull in traces and copper. Kinda cool...
I would like to check it out further to see if one can insert parasitics and actually create simulation models from data.
free idf reader
Here are the specs for IDF 2, 3 and 4
.idf files
The problem is that none of the major ECAD vendors are supporting 4.0 (https://www.priware.com/Common/Systems.aspx). Are any of the MCAD vendors?
mentor + idf + viewer
Check your CAD package. It might be able to download the idf file
