Looking for keypad encoder that takes less than 5V
osha
Member level 2
Member level 2
egypt
keypad encoder
i have only in my circuit 3.3v output and i want to drive keypad encoder i cant find keypad encoder take less than 5v,there for any one can help me to find (keypad encoder take 3.3v)
thanks for any help
keypad encoder
Why you don't use a simple converter 3.3 to 5V?
    osha
Re: keypad encoder
what this converter?PLEASE REPLY ME IN DETAIL,
THANK YOU FOR YOUR HELP:|
Re: keypad encoder
I believe there are some ic's for converting a voltage level (ex 3.3 V ) to anothe (5V).
you can search on google for them.
Added after 2 minutes:
What you want to make excactly?
Do you use a microcontroller?
Added after 4 minutes:
The following circuit is quite simple.
But be cereful :
When Vin=0V -> Vout=5V
When Vin=3.3V -> Vout=0V (0.2V)
You can also use a fet instead
Re: keypad encoder
i search but i can't found please if u can find it for me(it is will good help)
thank you
Added after 52 minutes:
sorry but i have only battry give only 3.3v there is no any source for 5v,so your ciricute need 5v.it's not solution,there are another solution.
