Looking for ISM Dual Band antenna with 430 and 868Mhz bands
asena
Member level 4
Member level 4
Portugal
dual ism diplexer
hello everyone
i am looking for an antenna that has the 430MHz and 868MHz bands on it.
Particularly, a dual-band base station.
I've been through many manufacturers, including the Amateur Radio antennas, but no one seems to have what i want.
Well... maybe i missed something.
Anyone knows of anything?
thanks
asena 8)
Re: ISM Dual Band antenna
Just a quick look at RFS (www.rfsworld.com) gave no results on dual-band antennas for cellular and trunking frequencies.
The closest match on your need would be a Kathrein antenna (model 739 990):
The only one at 440–512/824–960MHz... Check it out:
Hope this helps a little bit :)
mogwai.
Can you use a diplexer and two antennas?
mogwai.
Thanks!
That would be a good choice, if i neednt an omni-directional antenna!
Thanks for your input, i recorded the manufacturer!
regards
asena
Can do!
But i was trying to avoid that.
If my search is negative, ill have to look for a diplexer, or maybe a triplexer with more ISM band antennas.
thanks
regards
asena
