Looking for info about microstrip antenna
Microstrip antenna
Hi
It is a light, low profile,cheep and compact antenna that is made on PCB.
It's Invented in 1950's
Because of it's problems it is not used widely until 1970's.
Greetings
Mahdi
Re: Microstrip antenna
You can imagine a microstrip antenna just a simple two side PCB.
One side is almost out etched, only small portion in form of rectangle
or circular (and so on), so you get rectangular/circular microstrip antenna.
The dimension of the form must be chosen, so that the antenna work
effectively as a radiator. Also the thickness of the material of the PCB and
its dielectric charateristics.
The advantages of microstrip antennas are:
robust, low profile, you can attach it whereever you want, especially
you can hide it.
you can produce in mass with small intolerances. It becomes cheap.
The disadvantages are:
less directive (you must combine several antennas/array to get high gain),
low power antennas, and last but not least
microstrip antennas (and its derivative) probably, the most complicated
form of antenna to be analyzed
There are many good references on microstrip antennas :
Gupta K.C, Pozar, Hall etc
regards
The group of Prof. Wiesbeck, Karlsruhe Germany offers a comprehensive
lecture notes (in english).
the adresse
regards
all the PDFs are password protected! Do you have the password? I am not friendly with German...
Bye!
A google search? for the password? 8O
mmm...
What do you suggest for the search? "password of Prof. Wiesbeck" ???? :?:
