artem said:There was book uploaded "GSM architecture" (not sure about name ) it can help you .
xinxin said:relate to swtich spectrum or other?
rhjang said:If you mean the ORFS due to switching fail.
check your burst ramp up and ramp down curve.
The curve should be smooth, if not, ORFS due to switching may fail.
Try to calibrate your ramps.
northguy said:are you sure no problem for your pcb design?
K'unI said:the due to switch is PA on/off side efficent
so check you ramp profile
and PA power de-coupe capacitance
maybe too small
