Looking for info about digital AGC, calculating loop gain
abc1
Digital AGC
Could anyone help or direct me to information about digital AGC, calculate loop gain, time constant? Thanks in advance.
Re: Digital AGC
Digital AGC is a time discrete system. The speed is defined by the required gain range to cover and the amplitude detection dynamic range. If you have to cover 90dB and the measurement is 30dB you need minimum 3 steps to hit the right range and a last step to correct if the detection signal is within the range. If the gain setting or measurement process is some inaccurate you need possible a further step to finalize the AGC. Use a update rate which is integer multiple of the signal periodicy.
Digital AGC
u'd better search on google to find a Digital Downconverter's specification. In that, will always have a digital AGC, u may use that as a reference.
Re: Digital AGC
USE THE DIGITAL CONTROLLER TO CONTROL THE DIGITAL ATTENUATOR
