Looking for example of VCO design (300Mhz)
nj_jack
Member level 5
Member level 5
2015_designingvcoonfr4.pdf
can you take me example for VCO design?
frequency:300MHz about. thanks.
Re: VCO design.
Here is an example using ADS:
Re: VCO design.
This article describes a 900 MHz oscillator which scales nicely into 300 MHz.... easy to build and should provide very little troubble
That said, you did not tell us your need, wide band or narrow band, high performance or simple design!
If you narrow your request we will be able to provide more precise information!
/WebDog
VCO design.
I use it to generate clock signal for IC chip, so I am mainly concerned with its stability. Can you give some examples that are reliable and stable to work?
Re: VCO design.
    nj_jack
VCO design.
hello itaifrenkel
can you give me more information about ansoft application? I think ansoft is very good, but I don't master it.
