Looking for documents on RS232 and net
gorkin
Advanced Member level 1
brazil
RS232 and net
It would like to get greaters information on the standardization of interface RS232. Somebody has some information or document? It would also like to get greaters information on the possibility to be establishing connection some devices with interface RS232 in order to form a net of communications. Is possible this accomplishment?
Been thankful, Gorkin
RS232 and net
Look here
h**tp://w*w.lvr.com/serport.htm
as far as i understood you, i think u want to form a net or bus with the rs-232 interface.
i just know one example where a rs-232 bus was realized.
look at the dgt-boards which are used for playin chess via/against the computer.
theres a description of how to build a chessboard network for tournaments
its a network with up to 12 chess boards.
link to the homepage: http://www.dgtprojects.com
but i dont know how the communication between the boards work or if its documented... i think the data gets simply relayed and buffered between each node. imho there are better/faster and probably cheaper solutions than this one, since rs-232 was designed to enable point to point communication and not for bus communication. :)
FYI i have no experience with this i'm just saying my opinion.
HTH
dsp_
RS232
Hello brothers!
Very thanks for your's ansewers...good links Greats!
Yes "DSP", your undertand-me my necessity...but it's impossible what is due the physical implementation of RS232. I try with the RS485...
Thanks a lot!
try this
h??p://hjem.get2net.dk/villy/vje_vbio.htm
:idea:
Just to double check
are u planning on having a multidrop bus network of controllers?
