Looking for DC-DC converter: 24v to 12v, 8 amp
Fragrance
East Of Earth
24volt to 12v 8 amp
hi
i am looking for any schematic or guide for to make dc dc convertor for 24v to 12v with 8 amp out any idea or help
Re: 24volt to 12v 8 amp
I used the WEBENCH from National Semiconductor:
After keying the specs, WEBENCH recommended the following design:
In the design, LM2642 was employed. I checked the websites of LM2642 ( **broken link removed** ) and found few application notes on this buck regulator. Hopefully it helps. :)
maybe you can use a normal regulator with additional transistors in parallel with it to carry the current.
If you follow advice from the last post you will built yourself a heater..
You can obviously construct a dc/dc converter but ... for about $30-50 you can get one of-the-shelf... hmmm...something to think about...
try this
24volt to 12v 8 amp
good idea
    V
