Looking for cross to CUI POWER Supply 100W
zofiof
Member level 2
Member level 2
Hi
i'm looking for cross for
POWER Supply 100W output 12V 8.5A In115/230Vac
pn: VGS-100-12 mfr: CUI
datasheet: **broken link removed**
it's for my new schematic and i can accept with minor different in dimension and so
thanks in advance
What is the use of the supply, means what equipment will be connected to it ? Do you need the same structure of the supply ?
If not, you can use any PC supply instead. Use 12 volts output and ignore all other outputs. Is the simplest cross.
