Looking for code in ANSI C for Cryptography
gorkin
Advanced Member level 1
brazil
Cryptography and uC
Anyone have the full code in ANSI C for Cryptography like DES64 or DES128, AES128 or RAS?
I have in mind the implementation one of these algorithms is smart cards, it´s possible?
Thanks...
Gorkin
Re: Cryptography and uC
Thanks...
Gorkin
I guess you mean 8-bit uC, right? DES is not good choice in this case, even it can be implemented (check Keil installation - it has example of DES for x51). As to AES, one of the main requirement for cryptoalgorithms during AES contest was that they should be also optimized for smart card implementation. So, just check Google to download sources.
Also, I would recommend to give a look at Square algorithm. It is based on the same idea as Rijndael (and was developed by the same guys as well) and is very easy for implementation with low-level uC. RC4 is good choice if you need stream cipher.
Ace-X.
Cryptography and uC
I think TEA (Tiny Encription Algorithm) is useful for uC. I can post algorithm if you want.
Regards.
I dont know TEA algorithm, it´s ease for implemantation?
Please, post the algorithm or source code...it´s very usefull for my.
Gorkin
I have implemented RC4 on an 8051 a while ago (in assembler).
It is quite easy but needs 256 bytes of memory (xdata in my case).
best regards
TEA sources:
/http://www.simonshepherd.supanet.com/tea.htm
/http://www.simonshepherd.supanet.com/source.htm
DES for MSP430:
/http://www.expertis.com.mx/pdfs/DES4MSP430.PDF
Implementing IPsec on a 16-bit microcontroller:
/http://www.hta-bi.bfh.ch/Projects/ipsec/docs/implementing_IPsec.pdf
