Looking for circuit that converts duty cycle to voltage
masterx81
Member level 1
Member level 1
Hi to all...
I'm a beginner and I need a simple circuit that convert a signal of 150hz with variable duty cycle (from 0 to 100%) to a constant voltage proportional to the duty cycle...
I have tryed to find in internet, and I think that I need a lc filter (i am not sure...) , but I not say how calculate the values of the components...
Thanks to all!!!
constant voltage duty cycle
Use a R and C combination. R in serial, C in parallel with your load. I think this is the simplest form.
convert duty cycle to voltage
ok...
mmm... How i can calculate the exact value of the resistor and capacitor?
After the rc I think that i need also a transistor (because the load do not discharge the capacitor before the time), right?
Re: Duty cycle to voltage...
It depends on your load resistance.
Depends also on the output ripple than can be tolerated.
What is the signal source?Can it supply enough current to the load or should it be amplified beforehand?
Give some details.
This sounds like a what is used in a chopper. Can you be more specific about the input waveform? If you look on the net for "chopper circuit" you'll find some stuff!
the input signal is an inverted square wave (normal +12) with a variable duty cycle. The output need to be a variable voltage (form 0 to +5, 0 when the input is @ +12 -0% duty-) depending on the input duty...
I'm considering to use an operational amplifier...
yes, use an opamp integrator
Another little qustion...
Sorry for the banality of the domand but...
The opamp insert a little tension to the output(ca 2.5v), how i can remove it???
I'm using a tl074cn (quad opamp) with single supply (+12)
Thanks for the help!!!
Assuming you already have a DC voltage available to power your circuit, what you are looking for is called a DC-DC converter, they come in several varieties: buck, boost, buck-boost, flyback and other topologies that are mainly derived out of the above 4. There is lots of info about these circuits on the web, search in google.
Hi...
Assuming that the amplitude of input square signal is 12 V, you may get first an inversor. If the output sholud be 0 when input signal is 12 V, 0% duty, this may significates that in this moment, input signal is 12 VDC. This improve allows output DC signal increases when pulse width increases.
After this, you can converts the input-inverted-square signal, in a triangle signal, applying, for example, a Miller integrator. Based in triangle amplitude (that is proportional to pulse width), you may get the DC signal with, for example, simple diode-RC schematic; keeping low output ripple.
Typically, this solution should be non-linear.
Ok, I have find all the information but...
The opamp that I have, also in configuration voltage follower, when are at state low, they are @ ca 2,5volt (not 0...).
I'm using it with +Vcc->12v and -Vcc->Ground...
Whot I am doing wrong???
I need opamps designed for single power supply?
Thanks!
