Looking for circuit that can sense liquid levels
ramho100
could anybody help me by providing a ckt to sense any liquid(may be non conductive) level using change in resistance value(thru a float)
Thanks
Re: Circuit help
Thanks
Technically, if the liquid is not conductive then you can not use the method with resistance change. Quite logical, isn't it?
Re: Circuit help
Level of conductive liquid can be measured by measuring resistance between two electrodes. Level of nonconductive liquid can be measured by measuring capacitance between two electrodes. Ultrasonic distance measuring devices can be used on both types.
Re: Circuit help
Looks there is a mistake in presenting/understanding the problem. I had made a mention of float wherein i use reed contacts, as the float moves, it either keeps the contact open or close to its previous state and thus u can get diffarent resistive value.
That is specifically mentioned about the non conductivity of the liquid used. I can fairly sense the level, but how to measure it is my question
Thanks
Re: Circuit help
I suppose you are using the float
as a mean to turn the variable resistor.
If you can already sense the resistance,
you can power up the variable resistance,
and obtain the varying voltage.
This voltage can be a mean of indicator
to indicate the liquid level.
If you need to obtain a digital output,
you can use a ADC (analog to digital converter),
so that the information can be process by a computer.
Else you can interface the varying voltage to a circuit
which you might want to display directly.
www.siongboon.com
    ramho100
Re: Circuit help
Thanks for the reply. I was expecting a kind of reply like interfacing circuit for the TI chip xtr106/xtr117, these chips are basically used to transmit value for a longer distance in 4-20mA loop. My worry is how give input to this IC thru varying resistance.
