mr_ghz
Full Member level 5
Low_cost GHz VCO
Hi there,
I'm looking for a solution to build a cheap microstrip-VCO for 24GHz. The
frequency span has to be about +/-150MHz and more or less linear. The
output-power should be in the range of 0dBm and should not change
significant over frequency.
My current implementation is a parallel coupled oscillator with a comb-
filter. The frequency change is done by changing the drain-current of the
GaAs Fet. So I change the S21 phase and also the frequency. This is not
very linear and the output-power changes...
The use of a varactor-diodes gives a linear frequency but is a problem
because of the price. Because I need no 'high-end' oscillator we also tried
UHF varactors. This works but the frequency-span is low because of the
parasitic inductance.
Any idea?
Hi there,
Any idea?
