Looking for C code for converting float to int value
london
Member level 4
Member level 4
C code
Dear All,
This is my requirment,
float mV=0.0;
mV=(Count+23.484)/27.222;
result of mV will be xxxx.xxxxx
but finally i need the mV value in a integer means, xxxx only.
How can i get this. what is the another C code function i have to write to convert float to int value. if any body know help me!
Re: C code
I think you can use a type casting.
like this
mV=(int)mV;
Try this and tell me if it works.
ATLAJ
    london
Re: C code
Hi!
include the file "math.h" in your project and use the function
double x;
x = floor(mV);
x will hold the largest whole number not greater than mV
e.g if mV = 456.789;
then x will be 456.
If this does not solve your problem then feel free to ask.
Best of luck.
Regards.
    london
Re: C code
london said:
Dear All,
float mV=0.0;
By the way you know it's faster with the controller to calc
(500*Count + 11742)/13611 ?
by Gomez
