Looking for at45db641e 64 bit serial flash sample codes
chandu.kurapati
Full Member level 3
Full Member level 3
Bengaluru, India
Looking for at45db641e 64 mbit serial flash sample code
Hello,
AT45DB641E is a 64 mbit serial flash and it supports the SPI protocol to erase, read and write operations. I need to interface AT45DB641E with the micro controller.
Here i am unable to understand how to start with the coding. Please share if any one has sample code (or) application note, that would help me a lot.
Thanks & Regards,
Chandu.K
Re: Looking for at45db641e 64 mbit serial flash sample code
Did you read the datasheet?
Usually this information should be sufficient.
But maybe the manufacturer has additional documents like application notes, design notes, code examples...did you look for them?
We can't see what you have done so far. We even don't see how both devices are connected.
Klaus
