Looking for architecture specification and documentation for I2C
deepu_s_s
Full Member level 5
Full Member level 5
hello frnds,
I lost some data from my PC as the hard disk is damaged. I am doing a project on I2C. can anybody post me da architecture specification and documentation
Thanks n regards
Deepak
Need help
This Philips document should help you:
"The I2C Bus Specification", Version 2.1, January 2000
Need help
hi echo,
i refered to your doc. i am having a doubt in that.
1) first it was mentioned that the data on the SDA line cant be changed when SCL is high .
2)But later, is is given as the start and stop conditions are transitions of SDA from H-L and L-H respectively when SCL is high.
how could be this possible with reference to the first statement
pls refer to the link provided in the above post
thanks and regards
Deepak
Need help
You are probably looking at paragraphs 6.1 and 6.2. I agree that 6.1 isn't worded very well. I'm no I2C expert, but the seeming contradiction disappears if you focus on the word "data" in 6.1. Data bits must be stable during SCL high. The START and STOP conditions described in 6.2 are not data bits.
    deepu_s_s
Need help
sda cannot be changed when scl is high, except for you want give out a start, stop or rep-start condition.
Need help
ok i got ur points .... thank you
