Looking for an op-amp like LM741 but with lower noise
mhamed
Full Member level 1
lm741 footprint
Hi every one
I have dsigned a circuit with lm741 but its high input noise and its low slew rate is so bad for my circuite.is there an op-amp like lm741 but with lower noise and higher slew rate.note that is footprint must be same as 741.
thanks
Re: op-amp same to lm741
The TL071 is a jFET low noise, higher slew rate and has more bandwidth opamp.
Also the NE5534 is a much better opamp than the above, recomended for hi-fi audio.
