Looking for a zero crossing formula to ensure my test limits and parameters are ok
mseybold
Newbie level 1
Newbie level 1
Hello all,
Was wondering if someone could help me with an issue I am having. I have inherited a product which is no longer supported by the parent company. I am having intermittent issues with zero crossing failures.
In this test an AC voltage at about 1/3 scale and 120 Hz is applied to all high speed channels. A large offset is programmed into the DUT for all channels but one. Because the voltage is small it never reaches the magnitude of the offset programmed into those channels. Only the channel with no programmed offset triggers the zero crossing detector. Using this method, each channel is checked in turn until all channels have been checked and associated as voltages and zero crossing pairs.
I am looking for a zero crossing formula to ensure my test limits and parameters are correct in the test program. If anyone can lend some troubleshooting advice please contact me and I can share more information. Please see the attached schematic.
Thank you!
