Looking for a PSOC programmer circuit
AbdelHamid
Hello all ,
I can't find a PSOC programmer circuit , can u help me with it ?
I just found the one attatched see it.
ahmed
psoc programmer type 3
Have you ever try thid one. I found it in edaboard for a long time. But I can not remember where is its link?
edaboard cyp support device
review this link at edaboard,
regards,
psoc programmer download
Hi all,
I have released a stable freeware PSOC Programmer CYP which uses a very low cost hardware.
Regards
Ajith
You can find CYP (ver 1.42) here
psoc programmer 2+download
I have problem with PSOC Programmer
When i connect this circuit and CYP software .
this error " Device not found "
I used 74HCT245 instead of 4050.
programmer for 29466 psoc
Hi nooknikz,
Please make sure the connections from LPT are correct.Also make sure there is no inversion when you modified the circuit .This message appears when the chip is not detected or not supported.Make sure it is supported type.Make sure the correct port is selected and try again.Then it will be OK.CYP will autodetect the chip
if connections are correct.
Regards
Aji
cyp programmer download
New version of CYP (1.5)
Aji
psoc + 4050
hello please. i'm new to PSOC can anyone guide where to start and tell me if the programmer shown above really works and how to use it ... thank you all
psoc programmer aji
The Aji's programmer is works well. It supports CY21, 22, 24, 27, 29xxx families.
I have made it and sucessful.
Goto psocdeveloper.com to get the latest version.
Good luck
Regards,
H
cyp v1.9 freeware programmer
hello,
i maek the circuit type 3. but it doesnt work.
i try to program 29466.
but i think it cant recognize the programmer. because the warning message is same, when i connect or disconnect the programmer.
i used 74hc4050,q= bc557, res=47 ohm, diods=1n4448.
do i have to change the resistors and others ?
thank you.
psoc programmer circuit
You have to use CYP v1.5 and above! CYP 1.4 does NOT work with 29466.
