looking for a device to display my temperature
sanna
Member level 2
Hi
I have 5 temperature sensors and by cables they will be connected to a device with 1-5 inputs to display temperature. does anyone have a suggestion about the device which display the temperature? thanks for all advice.
you will have to make a custom made system for this purpose i think.
probably with microcontroller and LED 7 segment displays..
a MCU plus a LCD of 320x240 are enough, and you can display your temperatures simultaneously, although it seems to be a bit costly
It is a complex requirement so you should develop your own system for this problem.
