Looking for a circuit simulator (pspice) program.
xxtigerxx
Advanced Member level 1
Greece
I am looking for a circuit simulator (pspice) program.
The program must be graphical and easy to use.
Thanks..
I know LTspice it does not a lot of devices ( parts) only linear opamp and it is difficult to use it.
I will try the isimpe.
Thanks
Does anyone know anything other?
You need to specify your budget and intended use. There are loads of Spice simulators available. If you find LTspice difficult to use you will struggle with the rest - LTspice is one of the simplest ones to learn. Also, you need to get used to adding models to all simulators so the fact that LTspice only comes with LT models is not important.
Keith
i tried isim it is very easy to use and have quite good libraries
I think that is the best choice for free spice.
Keith I think with isim I am satisfy up to now. Can you please suggest me a more professional program. I need only schematic and pspice simulation.
Thanks
As I said before, you need to specify your budget. If you want "Pspice" then that is the version of Spice sold by Orcad (now part of Cadence). If you want "Spice" then there are dozens of options ranging from free ones to $100,000+
Keith
Keith
For a buget up to $5000, can you tell me a application?
For that sort of money Pspice would be a reasonable choice. Also, SIMetrix would be worth looking at. There are others but they are two that I have used. It partly depends on what you want to design with it - for example, do you want to do analogue or mixed signal IC design or only the design of discrete circuitry?
Also, the most expensive packages are not necessarily the "best". Have a look at Anasoft Superspice and Beige Bag http://www.beigebag.com/ for example. Where possible get a usable demo version before you spend your money.
Keith
