Looking for a cheap XCS10 replacement
twinsen
Full Member level 1
Full Member level 1
xilinx xcs10 price
Hi all
I would like to build the following:
h**p://www.baycom.org/bayweb/tech/eppjnx/eppjnx.htm
I see however that the xcs10 is ungodly in price. Is this because it is an obsolete part replaced by the Spartan 3 series?
Are the new parts backward compatible or will redesign or retargeting be necessary in ISE?
I am not very clued up in this field :(
Re: XCS10 replacement
Newer Spartans (Spartan 2 and Spartan 3) are not with the same
Pinout as Spartan and Spartan XL. Core and IO-Voltage are also
not the same.
Spartan2 have a very high startcurrent !! (>500 mA for 10ms)
But when your design in VHDL or Verilog it is not a great problem
to create a new fitting.
But when you must may a new design you can change to
Altera Cyclone.
if i read correctly the xcs10 is a 5V spartan FPGA.
I don't think that XCS10 is obsolete from xilinx, this is a old products, if you ned the same pinout you can try to use a major chip of spartan family qhit the same pachage if you think better, otherwise you can use any 5V fpga, you must every rewrite the code specially if you use a schematic whit fouyndation 3.3i.
Other solution is that you ask directly from Xilinx.
Bye.
G.
If could use TTL<->CMOS buffer to interface with Parallel port, You may able to use a new spartan device. Spartan II & IIE is possible to your design.
