Looking for a 24V DC power supply schematic
stevenash23
Junior Member level 1
please give me a schematic diagram for a power supply.
i need this for my project in electronics I. thanks!urgent..
Re: power supply
sir..i forgot to tell, the required input is 24V..thanks for your help..:D
Re: power supply
24v ac or dc?? what should be the o/p voltage??? 5v dc or12v dc??
Re: power supply
i think sir, hmmm.. both are 24V dc sir..
---------- Post added at 12:27 ---------- Previous post was at 12:26 ----------
i think sir, hmmm.. both are 24V dc sir.. and it will use as zener or regulator..hmmmm
Re: power supply
you are still confuse. all right
variable ps form 0 to 24v dc also with variable current till 2a.
hope this will help.
Re: power supply
the OP clearly has no idea what he wants. (the post is posted in the wrong section even). It will almost certainly be best for him to explain his exact requirements. input AC (or DC) voltages, isolation (and hipot voltages), and output voltages (and regulations/current requirements). The efficiency, cost, and size will likely be important as well.
