preethi19
Full Member level 5
Hi the transistor length that i am using is 6u. So my layout is something like this
Since the poly gate size is not big enough to place the contact as seen on the second transistor i need to use additional poly attached along the length of the poly gate. I learnt that using poly increases resistance and it is not advisable to use much of it. So should i layout poly along the whole side of the transistor length like for 1st transistor or just a small poly like the second one?? Either wat i am guess both would end up making a connection to the transistor gate. Any suggestions pls!!! Thank you!!!
